Poza tym nie rozumiem, dlaczego gra mialaby znalezc swoje miejsce na pecetach, skoro to ma byc przerobka oryginalu z nowym enginem (w sensie przystosowanym do xbox i obcietym otoczeniem), paroma ulepszeniami w mechanice i fizyce oraz skrotami w fabule (outdoor ma byc skrocony do rozmiarow indoor).
" The game's scenario does remain the same overall (although there are changes and adaptations) but there are plenty of gameplay improvements and additions, most notably the introduction of special abilities for main man Jack Carver."
As the Xbox has nowhere near the memory capacity that is needed to run the original game, you may be wondering where Ubi Soft have made the cuts. In the main, it's the huge expansive environment of Far Cry that has come under the developer's knife.
While there will be just as many trees present in any given area, Instincts won't have the variety of trees witnessed in the original. The deepest cut, however, is the number of islands, having been reduced from the original 22 to just four.
owszem, bardzo duże zmiany poczynili, gra wygląda bardziej realistycznie, szkoda, ze na PC nie potrafią takich efektów zrobić, choć odpowiednie sprzęty są
