Intel Core i9 (Gulftown) - 6 cores, 32 nm: hands-on review
Gulftown review - months before the launch
Real-world tests - Photoshop, file compression, encryption
Another benchmark was to perform 15 operations on a 38 megapixel image in Adobe Photoshop CS4.
Most of the filters and image transformations in Photoshop are not divided into multiple threads. More important than pure computing performance is memory bandwidth, especially witch such large images. Our Gulftown had its memory bandwidth limited by an early version of the BIOS, but was still ahead in the Core i5 test.
File compression and encryption
We tested simultaneous file compression and AES encryption. One of the few software applications that already use the AES-NI instructions is the latest version of WinZip. When creating archives In WinZIP 14, you can choose the compression type, encryption type and strength.
Simply select any AES encryption – hardware-based encryption acceleration will work immediately if you have an AES-NI enabled processor.
In encryption-free compression, Gulftown is not much faster than Core i7. In addition, WinZip compresses using a maximum of two threads, so the Gulftown’s entire advantage is related to its greater third-level cache capacity. When you turn the encryption on, Gulftown’s advantage becomes evident. Enabling encryption on non-AES processors results in compression times longer by 160-200%. On Gulftown, this causes compression to take 120% longer. Let us remember that in addition to encryption, the processor has to deal with file-packing – in typical cryptographic applications the advantage of using AES instructions will be much greater.
- 1.The Westmere processor family
- 2.Intel Gulftown ES
- 3.Test assumptions
- 4.Testing Rig
- 5.Synthetic tests – Sandra
- 6.Real-world tests – video encoding, rendering
- 7.Real-world tests - Photoshop, file compression, encryption
- 8.Synthetic tests – 3DMarks
- 9.Games
- 10.Power consumption and temperature
- 11.Overclocking and summary
- AMD Trinity APU – co wiemy o następcy Llano? 57
- Sandy Bridge E – testujemy procesory Core i7-3960X oraz i7-3930K 141
- AMD FX-8150 – mikroarchitektura Bulldozer i nowa generacja procesorów AMD 608
- Test procesorów za 300–400 zł 126
- Procesor AMD FX podkręcony do 8,4 GHz 155
- AMD APU A6-3650 (Llano) – tańszy model procesora Fusion ze zintegrowanym układem graficznym 96
- OC School – niedoceniane zalety chipsetu Intel X58, materiał wideo 32
- ASUS OC School, czyli szkoła podkręcania. Część 2. – niedoceniane cechy X58 45
- AMD A8-3850 (Llano APU) – pierwszy układ Fusion do desktopów 225
- Wyciskanie soków z Sandy Bridge – fakty i mity na temat podkręcania procesora oraz specjalnie przeznaczonej do niego pamięci 72
- Intel Core i7-990X – najnowszy sześciordzeniowiec Intela do najbardziej ekstremalnych zastosowań 70
- Intel Core i7-2820QM – test czołowego modelu procesora Sandy Bridge do laptopów 28
- Procesory Intel Haswell planowane na wiosnę 2013 7
- Procesory x86 wciąż przegrywają z ARM. Przez ceny 38
- IBM jednak nie będzie produkować procesorów AMD 20
- Nowe Athlony II X4 przeznaczone dla podstawki FM1 19
- Jagodowe Atomy dla telewizorów i set-top-boksów 5
- Istota "trójcy" według AMD: Piledriver, Northern Islands i...? 15
- 28-nanometrowe APU firmy AMD - oficjalnie dopiero za rok 14
- AMD "Trinity" w testach grafiki zmiażdży całą ofertę Intela. "Ivy Bridge" też 44
- IBM będzie produkować procesory AMD "Trinity" 25
- AMD anulowało 10- i 20-rdzeniowe procesory 20
- Google Bouncer – sposób na ostateczne rozprawienie się ze szkodliwymi programami w Android Markecie? 0
- JUŻ JEST AIWI MOTION DETECTOR KOZUMI W POLSCE! Dostępny tylko w ACTION! Sprawdź już dziś! 2
- Podróże z kamerą w samochodzie 1
- ZyNOS 4.0: nowe certyfikowane oprogramowanie IPv6 do przełączników ZyXELa 0
- Brennestuhl: domowy sprzęt elektryczny na wyciągnięcie ręki 1
- Niezależny test programów antywirusowych - dostajesz to, za co płacisz 2
- Komputronik Pro-DH600: kompaktowe desktopy dla firm 3
- Legendarne etui G-Form do tabletów na polskim rynku 5
- Genius na CES 2012 4
- Trojany kradnące dane bankowe atakują tysiące komputerów każdego dnia 0
- Xavax: tańsze ogrzewanie domu przez Internet 6
- Tablety Lark FreeMe: tak tanio jeszcze nie było 2
- Atak phishingowy na użytkowników Allegro - rzekome zwolnienie z prowizji 2
- Polska premiera kart Radeon HD 7950: Asus, HIS, Gigabyte 2
- 2011 - dobry rok dla graczy sponsorowanych przez SteelSeries. 2012 zapowiada się równie dobrze... 2
- 209i5 2500k czy fx 812001:26 | MaxForces
- 8Bogaty polak w USA01:24 | Twister.
- 28S8500 Wave I vs. SE XPERIA Neo V01:21 | Maledict
- 1093Lista polecanych kart dźwiękowych01:19 | Xender
- 0Radeon HD5700 problem z podłączeniem TV01:17 | FASTT
- 39komputer do 8000zł z monitorem01:10 | KMateusz
- 207Sandy Bridge za 170zł czyli Celeron G530 (2C/2T) 2,4GHz01:08 | mr.xxx
- 20Patriot vs Goodram vs Kingston do 200zł01:07 | Xender
- 1221Samsung Galaxy S 2...01:07 | EF
- 2kompsie nieuruchamia01:06 | afganno
- 476Phenom II - jaki potencjał oc ma twój phenom - ranking01:03 | rolandwally83
- 9301Steam - Temat Główny + FAQ00:41 | Sałat
- 14962Luźne fotografów rozmowy00:36 | Afterglow
- 3079World of Tanks00:29 | Pynio
- 359Klawiatury mechaniczne - dyskusja00:29 | Mr. 3
- 2160Lab znowu muli00:19 | Quicksand
