Intel Core i9 (Gulftown) - 6 cores, 32 nm: hands-on review
Gulftown review - months before the launch
Power consumption
We measured the power consumption of the entire test rig. Keep in mind that it is different from the one used in the recent processor reviews and the results are not comparable with the older ones. The processor, the main character of this article, is not the final product – it is an early engineering copy running on a board that provides unofficial support. The Power consumption may not represent the Gulftown processors we will see appearing in stores in a couple of months.
Our engineering copy was powered with 1.11 V under load and 0.95 V at rest.
Gulftown has about half more cores and half more cache than Core i7, and under load it draws ... about 24 watts less. As you can see, the 32 nm process technology has perfect effects on the power efficiency of processors, if you can pack 50% more transistors into a much smaller energy budget.
Operating temperature
We also measured the processors’ operating temperature. The temperature was measured using a digital thermometer with a K-type probe located on the side of the IHS.
Gulftown is one of the coolest processors we have tested so far. The temperature under load is comparable to processors that have two or three times less cores.
- 1.The Westmere processor family
- 2.Intel Gulftown ES
- 3.Test assumptions
- 4.Testing Rig
- 5.Synthetic tests – Sandra
- 6.Real-world tests – video encoding, rendering
- 7.Real-world tests - Photoshop, file compression, encryption
- 8.Synthetic tests – 3DMarks
- 9.Games
- 10.Power consumption and temperature
- 11.Overclocking and summary
- AMD Trinity APU – co wiemy o następcy Llano? 57
- Sandy Bridge E – testujemy procesory Core i7-3960X oraz i7-3930K 141
- AMD FX-8150 – mikroarchitektura Bulldozer i nowa generacja procesorów AMD 608
- Test procesorów za 300–400 zł 126
- Procesor AMD FX podkręcony do 8,4 GHz 155
- AMD APU A6-3650 (Llano) – tańszy model procesora Fusion ze zintegrowanym układem graficznym 96
- OC School – niedoceniane zalety chipsetu Intel X58, materiał wideo 32
- ASUS OC School, czyli szkoła podkręcania. Część 2. – niedoceniane cechy X58 45
- AMD A8-3850 (Llano APU) – pierwszy układ Fusion do desktopów 225
- Wyciskanie soków z Sandy Bridge – fakty i mity na temat podkręcania procesora oraz specjalnie przeznaczonej do niego pamięci 72
- Intel Core i7-990X – najnowszy sześciordzeniowiec Intela do najbardziej ekstremalnych zastosowań 70
- Intel Core i7-2820QM – test czołowego modelu procesora Sandy Bridge do laptopów 28
- Procesory x86 wciąż przegrywają z ARM. Przez ceny 6
- IBM jednak nie będzie produkować procesorów AMD 19
- Nowe Athlony II X4 przeznaczone dla podstawki FM1 15
- Jagodowe Atomy dla telewizorów i set-top-boksów 5
- Istota "trójcy" według AMD: Piledriver, Northern Islands i...? 15
- 28-nanometrowe APU firmy AMD - oficjalnie dopiero za rok 14
- AMD "Trinity" w testach grafiki zmiażdży całą ofertę Intela. "Ivy Bridge" też 44
- IBM będzie produkować procesory AMD "Trinity" 25
- AMD anulowało 10- i 20-rdzeniowe procesory 20
- AMD "Llano" podkręcony do 6 GHz. Wszystkie cztery rdzenie! 49
- Kolejne testy Ivy Bridge pojawiły się w sieci 25
- JUŻ JEST AIWI MOTION DETECTOR KOZUMI W POLSCE! Dostępny tylko w ACTION! Sprawdź już dziś! 1
- Podróże z kamerą w samochodzie 1
- ZyNOS 4.0: nowe certyfikowane oprogramowanie IPv6 do przełączników ZyXELa 0
- Brennestuhl: domowy sprzęt elektryczny na wyciągnięcie ręki 1
- Niezależny test programów antywirusowych - dostajesz to, za co płacisz 1
- Komputronik Pro-DH600: kompaktowe desktopy dla firm 3
- Legendarne etui G-Form do tabletów na polskim rynku 5
- Genius na CES 2012 2
- Trojany kradnące dane bankowe atakują tysiące komputerów każdego dnia 0
- Xavax: tańsze ogrzewanie domu przez Internet 5
- Tablety Lark FreeMe: tak tanio jeszcze nie było 2
- Atak phishingowy na użytkowników Allegro - rzekome zwolnienie z prowizji 2
- Polska premiera kart Radeon HD 7950: Asus, HIS, Gigabyte 2
- 2011 - dobry rok dla graczy sponsorowanych przez SteelSeries. 2012 zapowiada się równie dobrze... 2
- Impakt na DISTREE EMEA 2012 r. 0
- 13Internet nie taki anonimowy20:16 | SpiderWeb
- 33Allegro, problem z towarem.20:16 | Karol R
- 1184Samsung Galaxy S 2...20:16 | Baronik
- 1DC e670020:16 | ZIB2000
- 16[vid]Polski kibic na meczu w Austrii20:16 | bielas
- 1Google Chrome przycina czcionkę20:15 | mateck
- 51Tworzenie się skrótów folderów na pendrive.20:15 | bushto
- 168Dlaczego Jaruzelskiego nie zamknęli jeszcze za stan wojenny?20:15 | Keyser_Soze
- 28Samsung wave vs. N97 vs. X10 mini pro20:15 | Ationx
- 24217Wszystko na temat Playstation 320:15 | Jaycob
- 710Dell 22 Ultrasharp 2209WA matryca IPS20:12 | Pandel
- 245OPAMPY - temat zbiorczy20:12 | rayfe
- 432FAQ: APU FUSION (Llano & Bobcat) A-series, E-series Zacate, C-series Ontario20:10 | Alejajca
- 2398Battlefield 320:08 | Jaycob
- 185i5 2500k czy fx 812020:07 | ZIB2000
- 6239Co nowego w CD-Action?20:07 | Lypton
- 882Mass Effect 320:01 | bigdady35
